James_Wheelz
Dec 13, 2019Aspirant
Streaming issues on Xbox One X
So I'm confused as to which model I have so that's why I posted the image of the one I have and I got an additional satellite for this system. But for some reason on my xbox one x. Streaming gives poo...
Dec 15, 2019Guru - Experienced User
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
James_Wheelz wrote:
So I'm confused as to which model I have so that's why I posted the image of the one I have and I got an additional satellite for this system. But for some reason on my xbox one x. Streaming gives poor quality and I keep being disconnected from Call of Duty modern warfare 2019 servers. What should I do? I have beamforming on, UPnP is on, Ipv6 is on, mu mimo is on, daisy chain is on, and 20/40 mhz coexistence is on. Why is this happening? It's on firmware version is 2.5.0.38. Please help
James_Wheelz
Dec 16, 2019Aspirant
Also I'm in a house between 2 neighbors. Neighbor to the left of my house is about 15 feet away. Neighbor to the right is about 40 feet away. And when pulling up wifi one of their internet does show up when selecting which network to use.
