James_Wheelz
Dec 13, 2019Aspirant
Streaming issues on Xbox One X
So I'm confused as to which model I have so that's why I posted the image of the one I have and I got an additional satellite for this system. But for some reason on my xbox one x. Streaming gives poo...
James_Wheelz
Dec 16, 2019Aspirant
CGM4140COM first 0 is a zero and second 0 is a Oh. It's the Cox Panoramic Gateway. My house is about 6000 square feet. The satellites are about 30 feet apart. And my xbox is about 20 feet away from the satellite. So hardwiring isn't possible for me.
Dec 16, 2019Guru - Experienced User
If your ISP modem is a gateway, it probably already had built in wifi and a router.
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
I would try option #2 first...
