bboyd34
Aug 22, 2017Tutor
Streaming issues with Orbi
I have an ORBI router and satellite. Works great for the most part. However, two issues that creep up are streaming for Netflix and Amazon and some lag issues with my son's xbox. The router is upstai...
- Aug 23, 2017
You said your TV is near the satellite. Wire the TV if you can. I have my TVs wired. I wire everything I possibly can and reserve WiFi for devices that cannot be wired. Wired always works best.
bboyd34
Aug 23, 2017Tutor
It works but in watching a show or movie there will be times (sometimes serveral times) where it will buffer and take time before it starts playing again.
MarkC1024
Aug 23, 2017Luminary
Are you streaming via the TV's WiFi ? I had similar issues until I started running Netflix via my Xfinity box instead. I think most TV's have very poor WiFi chipsets.
