adrideba
Mar 16, 2018Aspirant
Streaming issues
Hi, I just purchased the netgear orbi and I am having buffering issues. I have a raspberry pi with kodi installed in it and I have a netgear nas 2 bay. Before I bought the orbi I was using the tp link...
adrideba
Thanks for your reply! It’s connected with a with a wire.. so I think frequency it will take the 5ghz! Right?
Mar 17, 2018Guru - Experienced User
How is the streaming device connected via wire? To the router or the Satellte?
- adridebaMar 17, 2018AspirantBoth are connected with a wire.. the nas streaming and raspberry pi.. they are connected to the satallite
- FURRYe38Mar 17, 2018Guru - Experienced User
What happens if you connect these devices to the router instead of the satellite.
- adridebaMar 17, 2018AspirantThe thing is i cannot do that because of how the setup is .. the modem is in another room because the wire of the isp is there and cannot move it .. the room where im trying has a good 100mbs download connection so its good the satallite is showing blue so good as well.. i donno what to do else! :(
