adrideba
Mar 16, 2018Aspirant
Streaming issues
Hi, I just purchased the netgear orbi and I am having buffering issues. I have a raspberry pi with kodi installed in it and I have a netgear nas 2 bay. Before I bought the orbi I was using the tp link...
Mar 28, 2018Guru - Experienced User
What is the model# of the ISP modem?
Also can you remove the RPi from the configuration and just connect the NAS up alone with the Orbi system and test?
adridebawrote:Before I had the Orbi, I was using the wall plugs because my ISP modem was in another room. Because of this problem I said maybe I put the ISP modem next to the router. I have the Arris as the ISP modem.
tsig
Mar 28, 2018Luminary
You don't have two routers working against each other do you? Either your ISP's router needs to be bridged or the Orbi needs to be in AP mode.
- adridebaJun 09, 2018Aspirant
So now I did the orbi as AP mode.. but still it's buffering every like 10 mins. I noticed that with every scene that requires a lot of rendering (heavy scene).. it stops to cache.
