RonaldJanssen
Dec 30, 2017Star
Streaming radio (in iTunes) interrups since using Orbi
Previously used the NightHawk R7000, no isseus with streaming radio stations (iTunes -> open stream) from my MBP (Wireless) on my Logitech UA Speaker (Wired). Since using the Orbi RBK53 the strea...
- Jan 06, 2018
Allright ..... well some new development here, hahaha.
I got this device from a friend (about 2-3 years ago), because he wanted to use it wireless and it was buggy as hell........
So I connected it with a cable and it worked flaweless. Until I got the Orbi.
But I thought well......it can't hurt to connect it wireless so I gave it a try. At the moment it is playing for about 2-3 hours and it didn't drop the connection a single time, hahahahaha
I leave it that way, problem is solved for me, just sharing my 2 cents.
DarrenM
Jan 03, 2018Sr. NETGEAR Moderator
Have you checked on Logitech community to see if that speaker is having issues with mesh systems?
DarrenM
- RonaldJanssenJan 05, 2018Star
Did some searching but nothing.
But anyway, it's connected by ethernet cable so how is that related to mesh systems?
