RonaldJanssen
Dec 30, 2017Star
Streaming radio (in iTunes) interrups since using Orbi
Previously used the NightHawk R7000, no isseus with streaming radio stations (iTunes -> open stream) from my MBP (Wireless) on my Logitech UA Speaker (Wired). Since using the Orbi RBK53 the strea...
- Jan 06, 2018
Allright ..... well some new development here, hahaha.
I got this device from a friend (about 2-3 years ago), because he wanted to use it wireless and it was buggy as hell........
So I connected it with a cable and it worked flaweless. Until I got the Orbi.
But I thought well......it can't hurt to connect it wireless so I gave it a try. At the moment it is playing for about 2-3 hours and it didn't drop the connection a single time, hahahahaha
I leave it that way, problem is solved for me, just sharing my 2 cents.
DarrenM
Jan 03, 2018Sr. NETGEAR Moderator
Have you checked on Logitech community to see if that speaker is having issues with mesh systems?
DarrenM
RonaldJanssen
Jan 05, 2018Star
Did some searching but nothing.
But anyway, it's connected by ethernet cable so how is that related to mesh systems?
