RonaldJanssen
Dec 30, 2017Star
Streaming radio (in iTunes) interrups since using Orbi
Previously used the NightHawk R7000, no isseus with streaming radio stations (iTunes -> open stream) from my MBP (Wireless) on my Logitech UA Speaker (Wired). Since using the Orbi RBK53 the strea...
- Jan 06, 2018
Allright ..... well some new development here, hahaha.
I got this device from a friend (about 2-3 years ago), because he wanted to use it wireless and it was buggy as hell........
So I connected it with a cable and it worked flaweless. Until I got the Orbi.
But I thought well......it can't hurt to connect it wireless so I gave it a try. At the moment it is playing for about 2-3 hours and it didn't drop the connection a single time, hahahahaha
I leave it that way, problem is solved for me, just sharing my 2 cents.
st_shaw
Jan 05, 2018Master
Please post a web link to information on "Logitech UA Speaker" A google search turns up nothing about this device.
You say the speaker is wired? How is it wired? In other words, what interface is used, 3.5 mm, Ethernet, USB, etc? What is the speaker wired to--your Orbi router, satellite, a switch, your MBP, etc?
Where is the stream located--is it on your LAN, on the Internet, etc?
