mikewickens
Nov 21, 2022Aspirant
Streaming RTSP Camera local Tapo c210 on Netgear RBK53 Orbi AC3000
Hi I got some new Tap cameras C210 was trying to connect via Windows 10 PC using VLC player to Stream using RTSP but I always get a network error. I have tested the ports are open using nmap util. ...
- Nov 21, 2022
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
mikewickens
I fixed it did a firmware upgrade all sorted
- FURRYe38Nov 21, 2022Guru - Experienced User
Enjoy. 📡
