JR_WEBS
Oct 22, 2019Aspirant
Streaming VidAngel-- RBR40
Team-- we use VidAngel to stream shows and movies from Netflix and Amazon through AppleTV. VidAngel allows you to mute "F-Bombs" and other language, as well as other inappropriate content. For some r...
Oct 22, 2019Guru - Experienced User
What modem are you running from centurylink?
I usually see them install combo devices (modem/router all in one). These tend to leave you with a double nat which can create just the problem that you're running into plus others.
https://kb.netgear.com/30186/What-is-Double-NAT
If you're basically using the orbi for wireless coverage, you can switch it to AP mode and that'll fix the double nat problem. (if thats whats going on)
Otherwise you'd need to put the cenurylink device in passthrough or modem only mode.
- JR_WEBSOct 22, 2019Aspirant
Yes-- Orbi is handling all the WiFi. Centurylink Wifi has been disabled and simply passing through.
- FURRYe38Oct 22, 2019Guru - Experienced User
Are you sure the modem is fully bridged? Just turning OFF the wifi on the modem is not enough. The modem has to be bridged or use its DMZ or IP Pass Through feature for the Orbi RBR in router mode. Or use the modem as your router and set the RBR for AP mode.
