ABR18
Dec 01, 2020Follower
Struggle setting up Orbi RBK13
Recently, bought a used Orbi RBK13 from ebay, followed all the steps right but somehow I am not able to login to the wifi named 'ORBI00' I resetted the orbi router, the setup says I am supposed to ...
Dec 01, 2020Guru - Experienced User
Try connecting a pc/laptop to the lan port. disable the wifi on the device you connect to it. Then attempt setup. This tends to go the smoothest for setup.
Also, when many reset, the just click the reset button. It needs to be pushed and held for 7-15 seconds while powered on.
Find manuals, guides, firmware here:
https://www.netgear.com/support/product/rbr10
