Jeremyrab
Oct 07, 2017Aspirant
Struggling to Port Foward on Orbi RBS50
I am trying to set up a minecraft server with the port 25565 but I just can't seem to get it working. So far I have tried disabling UPnP, Making my network a private network and disabling my firewall...
- Oct 07, 2017
Are you sure that your ISP modem is set to Bridged mode - if it's still acting as a router you need to either change it to bridged so that your Orbi is the router, or make the Orbi an AP and apply the port forwarding on the ISP router.
aaz
Oct 07, 2017Virtuoso
Jeremyrab
Oct 08, 2017Aspirant
After changing my modem into bridging mode had a bit of panic as speed slowed down a lot but after a reset speed is back up and port fowarding is working. Thanks so much
