iorishx
Jul 10, 2019Aspirant
Stuttering 4K playback with Orbi RBK40 wireless backhaul
Hello everyone. Been suffering from playing stuttering 4k on KODI from a SONY Z9F TV. My connection is: Ground floor: Kodi on SONY Z9F wired to RBR40 router, wireless to First floor: Windows 10 o...
Jul 10, 2019Guru - Experienced User
Has a factory reset and setup from scratch been performed since the FW update?
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
iorishx wrote:Hello everyone.
First floor: Windows 10 on PC wired to RBS40.
The distance is no more than 10 metres but on different floor. RBK40 with lastest firmware.
1080 or less is fine, but some of 4K seem to be too much for my RBK. Seems the backhaul speed is around 20 MBps
Any suggestions to improve my situation?
Thanks in advance.
Shaun
