pgerb4486
Sep 29, 2022Aspirant
Sub 50 mbps from satellites via 5g wifi or ethernet
Hi guys, were you able to figure out this issue? I've tried many of the tips on the forum but no luck. I have 500 mbps from my ISP, 300 from my router, and 40 from my satellites regardless if plugged...
Sep 30, 2022Guru - Experienced User
Any updates on this?
pgerb4486 wrote:
Hi guys, were you able to figure out this issue? I've tried many of the tips on the forum but no luck. I have 500 mbps from my ISP, 300 from my router, and 40 from my satellites regardless if plugged in or over wifi. Can't figure it out.
- pgerb4486Sep 30, 2022Aspirant
Thanks! The cbr40 v5.0.28
Satellite rbs20 v2.7.4.24
- FURRYe38Sep 30, 2022Guru - Experienced User
So i presume your seeing the lower speed with current FW loaded on the CBR and RBS?
I haven't tried current stuff on mine. However I was able to resolve that by going back to the version mentioned in my link.
Cool, did you roll back the satellites, router, or both?
