VinG
Jan 04, 2018Aspirant
Sudden issues connecting and satelite not found...
So my router is running V2.1.1.12, but the Satelite hasn't been updated, further I can no longer even see it via the Orbi app (why did the new app remove functionality to update firmware!?!?) nor fro...
DarrenM
Jan 08, 2018Sr. NETGEAR Moderator
You will need to get the satellite on the same firmware as the router are you able to find the ip address of the satellite? if so use that Ip address in your web browser then login to the unit and then do a manual update of the satellite.
DarrenM
