Casey_SJ
Apr 04, 2020Star
Suddenly cannot access one website, but an older router has no problem
This is a very strange problem. Let me explain: I've been using the RBR50 and RBS50 (satellite) for over a year without any problem. I've been accessing many different websites, including one i...
- Apr 05, 2020
UPDATE #2:
- I removed the Securifi Almond+.
- Configured the RBR50 back to Router Mode.
- Changed the MAC address of RBR50 to that of en0 from a computer I own.
- Rebooted the RBR50.
- Rebooted the Cable Modem (this is necessary).
Result:
- Problem Solved.
- So it seems the previous MAC address has been blacklisted somewhere along the route.
- Will contact the site administrator to see if there's anything they can do.
Thank you very much to everyone for your wonderful support. It's sincerely appreciated! :)
Casey_SJ
Apr 04, 2020Star
The router is on the latest firmware now -- 2.5.1.8.
As I mentioned, the inaccessible website is one that I visit frequently each day. It's an important site.
Resetting the router to factory defaults was an attempt to ensure that the problem was not due to any configuration changes I had made months ago with Port Forwarding.
Why would one website become inaccessible whereas an older router (Securify Almond+) has no trouble with that site?
The standard tech support protocol begins with:
- Reboot router.
- Check different browsers.
- Check virus software.
- Check firewalls.
- Make sure to explicitly type "https://"
- And yes, reset router to factory defaults.
All of these actions have been done.
Again, a different router has no trouble with the website. Just one website.
ekhalil
Apr 05, 2020Master
One of the reasons that can cause such strange -unjustifiable- issue is having double NAT in your network. If your ISP modem is acting as a router and does NATing on the incoming WAN traffic then this can cause different issues since Orbi is also doing NATing. You need to check if you have double NAT.
Please open a Command Prompt on any computer attached to Orbi and type:
> tracert 8.8.8.8 (or traceroute 8.8.8.8 if you're using a Mac computer)
1. If you see two private IP addresses listed in the first two hops then you have double NAT. Please check the model of your ISP modem and if you have a manual for it.
2. If you see only one private address and the second hop shows a public address, then you’re all good and we need then to troubleshoot further to find the root cause of the issue
- Casey_SJApr 05, 2020Star
Thank you for the suggestion. Would a double NAT issue affect all websites instead of just one?
traceroute 8.8.8.8 returns the following:
traceroute to 8.8.8.8 (8.8.8.8), 64 hops max, 52 byte packets 1 192.168.1.1 (192.168.1.1) 4.622 ms 3.107 ms 3.841 ms 2 96.120.88.81 (96.120.88.81) 13.323 ms 21.281 ms 11.697 ms 3 be-20009-rur02.sanjose.ca.sfba.comcast.net (162.151.30.233) 12.803 ms 15.035 ms 14.726 ms 4 be-331-rar01.hayward.ca.sfba.comcast.net (162.151.79.153) 12.676 ms 13.064 ms 16.728 ms 5 be-399-ar01.hayward.ca.sfba.comcast.net (68.86.143.89) 14.936 ms 14.911 ms 15.141 ms 6 69.241.91.94 (69.241.91.94) 14.647 ms 17.491 ms 96.112.146.10 (96.112.146.10) 14.585 ms 7 * * * 8 dns.google (8.8.8.8) 18.712 ms 15.007 ms 15.532 ms- ekhalilApr 05, 2020MasterYou don’t seem to have double NAT issue from those results. Will you get the same results if you make the traceroute on the problematic site?
The traceroute output for the problematic site is as follows. After 32 hops I interrupted it...please let me know if I should let it continue.
1 192.168.1.1 (192.168.1.1) 3.065 ms 5.333 ms 3.304 ms 2 96.120.88.81 (96.120.88.81) 12.977 ms 15.262 ms 10.676 ms 3 be-20009-rur02.sanjose.ca.sfba.comcast.net (162.151.30.233) 22.645 ms 12.298 ms 13.109 ms 4 162.151.78.85 (162.151.78.85) 12.932 ms 20.787 ms 11.730 ms 5 be-231-rar01.santaclara.ca.sfba.comcast.net (162.151.78.249) 10.850 ms 12.999 ms 27.275 ms 6 be-3651-cr02.sunnyvale.ca.ibone.comcast.net (68.86.91.73) 19.151 ms 12.763 ms 13.810 ms 7 be-11025-cr01.9greatoaks.ca.ibone.comcast.net (68.86.87.158) 13.531 ms 13.730 ms 15.305 ms 8 be-11525-cr02.losangeles.ca.ibone.comcast.net (68.86.84.149) 21.576 ms 23.220 ms 28.814 ms 9 be-11523-cr01.houston.tx.ibone.comcast.net (68.86.87.174) 50.537 ms 50.327 ms 50.770 ms 10 be-11423-cr02.56marietta.ga.ibone.comcast.net (68.86.85.21) 65.545 ms 63.314 ms 66.001 ms 11 be-1302-cs03.56marietta.ga.ibone.comcast.net (96.110.32.77) 62.336 ms 65.122 ms 64.576 ms 12 be-2301-pe01.56marietta.ga.ibone.comcast.net (96.110.32.94) 63.883 ms 62.542 ms 70.851 ms 13 75.149.230.90 (75.149.230.90) 61.299 ms 63.916 ms 63.088 ms 14 * * * 15 * * * 16 * * * 17 * * * 18 * * * 19 * * * 20 * * * 21 * * * 22 * * * 23 * * * 24 * * * 25 * * * 26 * * * 27 * * * 28 * * * 29 * * * 30 * * * 31 * * * 32 * * *
If it helps, this is the result of traceroute to www.cnn.com, which is fully accessible:
traceroute to turner-tls.map.fastly.net (151.101.41.67), 64 hops max, 52 byte packets 1 192.168.1.1 (192.168.1.1) 3.045 ms 1.144 ms 4.458 ms 2 96.120.88.81 (96.120.88.81) 10.732 ms 14.537 ms 10.625 ms 3 be-20009-rur02.sanjose.ca.sfba.comcast.net (162.151.30.233) 13.099 ms 14.568 ms 12.683 ms 4 162.151.78.85 (162.151.78.85) 12.784 ms 15.831 ms 12.786 ms 5 be-231-rar01.santaclara.ca.sfba.comcast.net (162.151.78.249) 14.616 ms 16.126 ms 51.265 ms 6 be-3651-cr02.sunnyvale.ca.ibone.comcast.net (68.86.91.73) 15.067 ms 14.794 ms 14.589 ms 7 be-21025-cr01.9greatoaks.ca.ibone.comcast.net (68.86.84.250) 13.843 ms 15.001 ms 23.816 ms 8 be-2211-pe11.9greatoaks.ca.ibone.comcast.net (96.110.32.246) 15.305 ms 15.882 ms 14.976 ms 9 * * * 10 * * * 11 * * * 12 * * * 13 * * * 14 * * * 15 * * * 16 * * * 17 * * * 18 * * * 19 * * * 20 * * * 21 * * * 22 * * * 23 * * * 24 * * * 25 * * * 26 * * * 27 * * *
