Casey_SJ
Apr 04, 2020Star
Suddenly cannot access one website, but an older router has no problem
This is a very strange problem. Let me explain: I've been using the RBR50 and RBS50 (satellite) for over a year without any problem. I've been accessing many different websites, including one i...
- Apr 05, 2020
UPDATE #2:
- I removed the Securifi Almond+.
- Configured the RBR50 back to Router Mode.
- Changed the MAC address of RBR50 to that of en0 from a computer I own.
- Rebooted the RBR50.
- Rebooted the Cable Modem (this is necessary).
Result:
- Problem Solved.
- So it seems the previous MAC address has been blacklisted somewhere along the route.
- Will contact the site administrator to see if there's anything they can do.
Thank you very much to everyone for your wonderful support. It's sincerely appreciated! :)
Casey_SJ
Apr 05, 2020Star
Those are great ideas about blacklisting -- and that makes a lot of sense. Will attempt that next, but here's an interim update:
I just did the following:
- Disabled WiFi on the old Securifi Almond+ router.
- Installed the Almond+
- Switched the RBR50 to AP Mode (access point).
- Rebooted the cable modem to establish a link with the Almond+.
Result:
- The target website is FULLY ACCESSIBLE over WiFi through the RBR50 in AP Mode.
- Even though this is temporary, I am overjoyed to see this! Wow.
I can certainly change the RBR50's MAC address next.
Casey_SJ
Apr 05, 2020Star
UPDATE #2:
Result:
- Problem Solved.
- FURRYe38Apr 05, 2020Guru - Experienced User
GLad you got it working. Be sure to do a backup configuration to file for safe keeping. Saves time when a reset is needed.
Enjoy. :smileywink:
