TRH
Apr 01, 2019Aspirant
Suddenly can't login at orbilogin.com
Been using for a few years now and no problem logging in to orbilogin.com. Today I tried and a message popped up that my password wasn't secure. It wanted me to change it and add two security questio...
- Apr 02, 2019Thanks. It worked.
CrimpOn
Apr 02, 2019Guru - Experienced User
Perform a "Reset to Factory" (look at videos on the web for instructions). This will wipe out everything and allow you to set it up from scratch.
Yes, the newest firmware is pedantic about wanting users to create more "secure" passwords. I believe you can simply ignore the prompts and make the password whatever you want.
- FURRYe38Apr 02, 2019Guru - Experienced User
I walked thru a new RBR50 setup last nite. I set a simple 4 character PW, set questions, started the wizard walk thru then was told that the PW as to simple and that I needed to change it. I did however there was a skip button. Talk about pedantic. :smileytongue:
- TRHApr 02, 2019AspirantThanks. It worked.
Enjoy. :smileywink:
