TRH
Apr 01, 2019Aspirant
Suddenly can't login at orbilogin.com
Been using for a few years now and no problem logging in to orbilogin.com. Today I tried and a message popped up that my password wasn't secure. It wanted me to change it and add two security questio...
- Apr 02, 2019Thanks. It worked.
CrimpOn
Apr 02, 2019Guru - Experienced User
Perform a "Reset to Factory" (look at videos on the web for instructions). This will wipe out everything and allow you to set it up from scratch.
Yes, the newest firmware is pedantic about wanting users to create more "secure" passwords. I believe you can simply ignore the prompts and make the password whatever you want.
