noudess
Oct 30, 2023Tutor
Suddenly none outside can reach my network (Orbi RBR50)
I haven't changed anything.
It's been so long. The only IP address I see when logging into the orbi is on the 10.*.*.* subnet which I know is private. Is my ISP failing to provide an externally r...
- Nov 07, 2023
This is resolved. The ISP switched me to a private IP and we addressed it with them.
schumaku
Oct 30, 2023Guru - Experienced User
noudess wrote:
I dont have a cable modem like I did will all previous ISPs before I moved here.
Looks like a CPE installation of a wireless PtP or PtmP Internet connection to me.
Certainly not a Orbi issue, much more likely the ISP has changed the connection to some kind of CGN (or NAT in the view of the private IP range - very cheap for such a service) connection under the pressure of the IPv4 shortage.
We will hear tomorrow from the customer with the answer from the ISP.
noudess
Nov 07, 2023Tutor
- FURRYe38Nov 07, 2023Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
