stevep422
Apr 18, 2019Aspirant
Suggested on Modem/gateway for RBR50
I'm looking for suggestions on a reliable modem/router gateway for my RBR50. The existing Netgear AC1200, Model R6220 needs to be replaced. I'm using the Orbi soley for wifi connections throughout ...
stevep422
Actually I called them today to ask that question. The service provider is the local power company. They didn't recommend anything. I guess what I'm really wondering since I need something in front of the RBR50 is there a particular model router that would work best? It's not a cable connection. Or, should I not even worry about it?
CrimpOn
Apr 18, 2019Guru - Experienced User
The consensus on the forum is that you want only one router between you and the ISP and only one WiFi network. Since a "modem only" device is less expensive than a "modem/router", the typical purchase would be a DOCSIS 3.0 "modem" and let the Orbi perform the router functions. There are some people who have specific router needs that they feel the Orbi does not fulfill, so they opt to purchase a "modem/router? and put the Orbi into Access Point (AP) mode. My guess is that you do not fall into that category.
If the fiber unit has an RJ45 (ethernet) connector instead of a coax (cable) connector, I would first try plugging the Orbi directly into the fiber unit.
- stevep422Apr 20, 2019Aspirant
"If the fiber unit has an RJ45 (ethernet) connector instead of a coax (cable) connector, I would first try plugging the Orbi directly into the fiber unit."
So I connected the Orbi directly and everything worked fine. I'm not sure why I had it in my head I had to have a modem in front of it. I've moved all the wired and wireless devices in our facility over and everything is working fine.
Thanks to everyone for thier suggestions!
- FURRYe38Apr 22, 2019Guru - Experienced User
Glad it's working well. Enjoy.
Please mark your thread as solved so others will know for future reference.
