perrynmyers
Sep 27, 2020Star
Support for addn_hosts in dnsmasq on Orbi RBR50
Hi, I'm reviving a topic from 2018/2019 that has been closed for inactivity, because the issue still exists and has not been resolved yet. This is related to the closed thread: https://community.ne...
Sep 27, 2020Guru - Experienced User
Something to psot about here:
https://community.netgear.com/t5/Idea-Exchange-For-Home/idb-p/idea-exchange-for-home
Good Luck.
- perrynmyersSep 27, 2020Star
Thanks for the suggestion. When NG Technical Support redirected me to the Community Forum to post this, they did not tell me where in the forum I should go.
I have posted it here now:
Thanks again :)
- FURRYe38Sep 27, 2020Guru - Experienced User
Good Luck. :smileywink:
Reposting this idea here, in case it helps someone out and Netgear doesn't implement support for this in the Orbi firmware itself.
In case anyone is interested in a bit of an extended hack, here's a script that you can use (using the expect utility in Linux) to log into the Orbi and configure dnsmasq programatically. This way when the Orbi reboots, you simply re-run the script.
It allows both usage of /tmp/dhcpd_hostlist which uses the name each client identifies with (which often can be unset) but it also allows you to put a hosts file on a FAT32 formatted USB stick and put that USB stick into the Orbi Router which on the RBR50 is accessible via /mnt/sda1
Script:
#!/usr/bin/expect set addn_hosts "addn-hosts=/mnt/sda1/hosts\naddn-hosts=/tmp/dhcpd_hostlist\n" set host "192.168.1.1" set user "admin" set password "********************" set timeout 20 spawn telnet $host expect "login:" send "$user\n" expect "Password:" send "$password\n" send "grep -qF addn-hosts /etc/dnsmasq.conf || (echo \'$addn_hosts\' >> /etc/dnsmasq.conf && echo 'addn-hosts added')\n" send "pidof dnsmasq\n" send "kill \$(pidof dnsmasq)\n" send "/usr/sbin/dnsmasq --except-interface=lo -r /tmp/resolv.conf\n" send "pidof dnsmasq\n"
If you don't want to supply a separate hosts file (in the format of ip_addr hostname, with each mapping being a separate line), then you can just remove the addn_hosts=/mnt/sda1/hosts from the addn_hosts variable in the script. This will make it so the only hosts file used is /tmp/dhcpd_hostlist
But if you format a USB drive as FAT32 (or vfat) and put a hosts file on it, you can then arbitrarily configure the Orbi DNS server with whatever local DNS names you want.
Hope this helps someone out.
