perrynmyers
Sep 27, 2020Star
Support for addn_hosts in dnsmasq on Orbi RBR50
Hi, I'm reviving a topic from 2018/2019 that has been closed for inactivity, because the issue still exists and has not been resolved yet. This is related to the closed thread: https://community.ne...
Sep 28, 2020Guru - Experienced User
You might query Voxel over on the SMB forums to see if his FW better supports this:
- perrynmyersSep 28, 2020Star
Thank you for the pointer. I wasn't aware of this alternate firmware. That said, I think I'll try to stick with the stock firmware if the worst thing I need to do is telnet in an set up a single line in dnsmasq.conf with a hosts file. Seems less invasive than swapping firmwares (for now). Thanks!
- FURRYe38Sep 29, 2020Guru - Experienced User
Voxels Fw is mostly the same. Behind the scenes packages are kept more up to date. Something to review.
Good Luck.
