th3w01f
Sep 03, 2016Apprentice
Support for multiple SSIDs?
Will Orbi support multiple SSIDs in any fashion (by radio, VLAN, etc) at launch or in the near future?
DarrenM
Sep 06, 2016Sr. NETGEAR Moderator
Hello th3w01f
The orbi is planned to support a guest network in a future firmware but right now just 1 ssid
DarrenM
- th3w01fSep 23, 2016Apprentice
This answer changed from when it was first posted. Initially the response was that I could use separate SSIDs on the 2.4 and 5Ghz radios, now that I'm trying to set up the Orbi, I find that the original answer was changed and that is not supported. At the very least, Netgear should have owned the incorrect response and posted the correct info, and not made it look like they provided the answer the first time. This screws up my network and forces me to change the SSID on 30 devices
