joshjoshjosh42
Apr 15, 2017Guide
Support for vLAN tagging?
As per the title, when will vLAN tagging support be added into the Orbi system natively? Currently I am running the Orbi through a cheap and (not so) cheerful router provided by Vodafone which has na...
- May 12, 2017
Basic VLAN is supported by ORBI a more advanced version of the VLAN tagging is coming in near future.
DarrenM
captbrando2
Apr 26, 2017Guide
I will second this request. There is a real need for a mesh WiFi setup that will work in AP mode to tie a VLAN to an SSID. Guys, why are you not opening this feature up? You clearly have the knowledge and capability as you solved the problem for Singapore. What about the rest of us?
