joshjoshjosh42
Apr 14, 2017Guide
Support for vLAN tagging?
As per the title, when will vLAN tagging support be added into the Orbi system natively? Currently I am running the Orbi through a cheap and (not so) cheerful router provided by Vodafone which has na...
- May 12, 2017
Basic VLAN is supported by ORBI a more advanced version of the VLAN tagging is coming in near future.
DarrenM
joshjoshjosh42
Jul 06, 2017Guide
Phil, I've since updated the firmware and it supports VLAN tagging for ISP connectivity - I use it with Vodafone's "FibreX" directly into the Orbi router. Go to the advanced tab and you can configure VLAN tagging as per your ISP under one of the bottom sidebar tabs from memory.
- PhilNoSpillJul 06, 2017Initiate
AH - looks like it was resolved for the RBK50 units. I'm still waiting on a response for the RB40R / RBK40 from Netgear. The latest firmware I got (1.11.0.20 still doesnt have the feature under advanced settings). Either way it makes the "Easy Setup" a bit of a nightmare in NZ currently.
- AlgesterJul 16, 2017Guide
Hi,
I recently got the AC3000 but am having trouble connecting to TPG NBN connection here in Australia. The requirement is:
"...For TPG NBN, you need to enable VLAN tagging and set the WAN VLAN ID = 2. Should be listed as an option called VLAN or 802.1Q..."
I also have a R7000 and the TPG connection works fine but with the RBR50 in router mode the vlan tagging doesnt seem to work for me. So currently running the RBR50 in access mode.
Anybody else on TPG having this problem? or any suggestions?
