Drake0508
Jan 16, 2017Star
Support Phone Number
I have looked on the website but cannot find the number to phone Support. I am trying to register my device and the website is telling me that the device has already been registered. Any help would be...
DarrenM
Jan 17, 2017Sr. NETGEAR Moderator
Hello Drake0508
If you could send me a private message with the serial number of the product and your email I will try to get the info to support or look into why its already registered.
DarrenM
- William4u4Mar 31, 2018Initiate
I hate companies that sell you stuff then say upgrade and then there is no phone support and the site does not have the corect info when you try and follow the email they send you
- vconrad16Oct 04, 2018AspirantI updated to the latest firmware, 2.2.1.210 and now I cannot connect to the internet, no Wifi or very sporadic connection. Cannot find a number to call. System was working perfectly prior to update. This problem is caused by you and I cannot get help
- FURRYe38Oct 04, 2018Guru - Experienced User
Try a factory reset and set up the system again from scratch with the modem. Walk thru the setup wizard with a wire connected PC and Browser connected to the routers web page at 192.168.1.1.
