jimgiordano
Aug 13, 2019Follower
Supported satellites for RBR50
I'm looking for a list of models of satellites that are supported to work with RBR50.
- Retired_Member
jimgiordano wrote:
I'm looking for a list of models of satellites that are supported to work with RBR50.perhaps this will help:
https://community.netgear.com/t5/Orbi/RBR50-and-adding-satellites/m-p/1712862
This is some good info:
Most RBS or RBWs will connect to the 50 series system. Just the speed rates seen on lower model RBS will change as they don't support the same backhaul speeds as the RBS50 do.
