sparta1
Dec 07, 2016Follower
Surface Pro 2 with Orbi - Slow Performance
Orbi was setup over the weekend. Massive upgrade coming from an RT-N66U. Everything is performing very well except for my Surface Pro 2. It has very poor performance off the router and almost unusable performance off the satellite. I've disabled Beamforming as suggested for the similar issues with the older iOS systems. This did not make a difference. Any other ideas? Should MU-MIMO be turned off also? I'm running the latest firmware on both.
1 Reply
- DarrenMSr. NETGEAR Moderator
Hello sparta1
You could try disabling mu-mimo as well see if that improves anything.
DarrenM
