michail71
Dec 29, 2018Apprentice
Surface/Orbi Picking 2.4G over 5G
My Surface Pro 4 likes to pick up the 2.4G channel on my Orbi setup which results in degraded performance. For now I disabled 2.4G in the device manager on the Surface. It's been my experience the ...
Dec 29, 2018Guru - Experienced User
What FW is currently loaded?
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
What WPA security modes are you using?
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Disney Circle: https://community.netgear.com/t5/Orbi/WARNING-Firmware-2-2-1-210-is-junk/m-p/1667485/highlight/true#M45926
If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually. https://community.netgear.com/t5/Orbi/RBK50-Backhaul-Status-Poor-After-Firmware-Update-2-1-4-16/m-p/1680907/highlight/true#M48123
https://community.netgear.com/t5/Orbi/quot-Reverse-quot-Daisy-Chain-issue-any-update/m-p/1653439
https://community.netgear.com/t5/Orbi/Orbi-RBR50-Slow-Wired-WAN-after-2-2-1-210-Upgrade/m-p/1667058/highlight/true#M45881
michail71 wrote:
My Surface Pro 4 likes to pick up the 2.4G channel on my Orbi setup which results in degraded performance. For now I disabled 2.4G in the device manager on the Surface. It's been my experience the WiFi chips/antennas in the Surface linuep are quite terrible!
Anyway, this got me to thinking is it a good idea to put the two frequencies on the same SSID? Manufacturers like to do this now but it has only caused problems for me.
- Barney67Jan 01, 2019Aspirant
I had the same problem, I overcame it by changing the SSID of 5GHz Wifi. I configured my devices to then only use that SSID.
Instructions are here
