Aw_Shucks
Apr 08, 2019Aspirant
Switch from 5ghz to 2.4ghz
I actually have an Orbi RBR40 with 2 RBR20 Satellites and I'm trying to link my greenie lights to my network. My satellites and phone are both on the 5ghz band. I reset my bulbs and they are blinking...
- Apr 08, 2019
Disable the 5Ghz SSID broadcast Under Advanced Tab/Advanced Settings/Wireless Settings
There will be a check box there, uncheck it and save settings. Re-check it after you have setup your devices.
eddard
Apr 09, 2019Aspirant
A thousand times thank you! I got mine hooked up and was loving it I tried to add my 2.4 switches. I saw the Telnet fix but didn't want to go that route (yes,a router pun). Found this and now I'm good to go!
