caesar99
Feb 16, 2021Follower
Switch from Wireless to Wired (RBS50v2 Satellite)
Moved one satellite to a new room which has an ethernet connection to my FiOS router in the basement. Thus, it was previously connected via 5G, now I want to move it to wired. I rebooted/shut down ...
Feb 16, 2021Guru - Experienced User
The satellites needs to connect to the orbi router or even through a switch.
If you're in a double nat (2 routers in router mode on the network) its not connecting on the same subnet as the router.
connecting to the fios router implies you're running 2 routers on the network.
