orbimesh
Oct 22, 2019Aspirant
Switch stipped working
Have an Orbi rbk50 connected to optimum router . From Orbi have a multiport Luxul switch . Wired connections stopped working . Tried rebooting , turned on off DHCP settings and rebooted . Any tips ?
- Oct 23, 2019
Hi,
I'm glad you sorted the issue :)
Looks like you probably created a loop on your switch which caused your issues?
CheerZ
Fl1ntstone
Oct 23, 2019Apprentice
Hi,
Have you checked the ethernet cables used for the switch? If the ethernet cables are ok then your switch could be 'toast'? Have you also tried directly connecting to the Orbi to check that the ethernet port that the switch is connected to is ok?
CheerZ
orbimesh
Oct 23, 2019Aspirant
If I unplug all the lan ports on Orbi works well for WiFi. Satellites change to magenta color too. I’ll test with new cables again . Just got new Firmware update installed as well. Not sure if switch from Luxul and Orbi dhcp fighting (if that’s how to say it !)
