orbimesh
Oct 22, 2019Aspirant
Switch stipped working
Have an Orbi rbk50 connected to optimum router . From Orbi have a multiport Luxul switch . Wired connections stopped working . Tried rebooting , turned on off DHCP settings and rebooted . Any tips ?
- Oct 23, 2019
Hi,
I'm glad you sorted the issue :)
Looks like you probably created a loop on your switch which caused your issues?
CheerZ
Oct 23, 2019Guru - Experienced User
What is the MFr and model if this switch your using.
There are known incompatibilies with some switches that are managed or have Green Ethernet features.
orbimesh
Oct 23, 2019Aspirant
Looks like had a wire plugged in both ends to a connected switch . Working now ! Thanks again .
- FURRYe38Oct 23, 2019Guru - Experienced User
Glad it was a simple fix. Please mark your thread as solved.
Enjoy.
- Fl1ntstoneOct 23, 2019Apprentice
Hi,
CheerZ
