orbimesh
Oct 22, 2019Aspirant
Switch stipped working
Have an Orbi rbk50 connected to optimum router . From Orbi have a multiport Luxul switch . Wired connections stopped working . Tried rebooting , turned on off DHCP settings and rebooted . Any tips ?
- Oct 23, 2019
Hi,
I'm glad you sorted the issue :)
Looks like you probably created a loop on your switch which caused your issues?
CheerZ
orbimesh
Oct 23, 2019Aspirant
Looks like had a wire plugged in both ends to a connected switch . Working now ! Thanks again .
Fl1ntstone
Oct 23, 2019Apprentice
Hi,
CheerZ
