whsbuss-1
Mar 29, 2017Apprentice
Switch to closet and stronger Orbi
So I have the 2 unit Orbi setup. I have one on the 2nd floor in the center of the house, the satellite on 1st floor opposite side of house. So when I open my Macbook Pro after being on 2nd floor (I d...
st_shaw
Mar 29, 2017Master
OSX clients do not roam the same as phones.
Details are at the below Apple link. The text to pay attention to is this, "OS X clients monitor and maintain the current BSSID’s connection until the RSSI crosses the -75 dBm threshold." This means your MacBook won't switch between Orbi APs unless the signal drops below -75 dBm.
https://support.apple.com/en-us/HT206207
You might think Orbi could boot the Mac and cause it to reconnect, but that could cause an infinite loop of disconnects, so that approach is not usually used.
- whsbuss-1Mar 29, 2017Apprentice
st_shaw wrote:OSX clients do not roam the same as phones.
And there is no way to change that in the macOS client. And unlike a Ubiquini AP there is no option to drop clients when the RSSI drops below a user-set value. Now maybe I can find an option on the Mac to turn off wifi when the lid closes.
