Chad6298
Jan 16, 2021Follower
Switched to AT&T Fiber from Spectrum
My AT&T router/modem is connected to the internet, but my Orbi wont connect to the internet. I factory reset the orbi router but it still won’t connect. It connects to the 2 satellites but not the int...
Jan 16, 2021Guru - Experienced User
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Chad6298 wrote:
My AT&T router/modem is connected to the internet, but my Orbi wont connect to the internet. I factory reset the orbi router but it still won’t connect. It connects to the 2 satellites but not the internet. Does anyone know how to get the orbi connected to the internet? One of the support personnel I talked with at AT&T said the tech should of done a IP passthrough.
