PKleeberg
Nov 24, 2021Tutor
Switching backhaul from wifi to wired caused problems...
Guess the old adage if it ain't broke don't fix it applied here. After years of use I decided to try and switch my Orby router and satellites to an ethernet backhaul from Wi-Fi. The Orbi router i...
PKleeberg
Nov 25, 2021Tutor
The saga goes on....
I connected the distant satellite (2) to ethernet and orbilogin.net shows that it is wired with a good backhaul status however there are many devices that no longer appear on the web page. the iPhone app shows the status of these missing devices as offline. I am able to use terminal to log into one mac mini with a fixed IP that shows as offline and so a sudo restart. I am able attach to it with either via IP or with "Network" in the finder to see the screen.
Also interesting, a hard wired Apple TV, sitting right next to Satellite 1 still using a WiFi backhaul, cannot be seen by either that web interface or the iPhone app. I am able to ping it.
I am reluctant to reset the devices to factory. It took me a long time to get this right since so many of my devices have fixed IPs and I have a fixed IP Internet connection.
BTW, firmware V2..7.3.22. "the latest"
Any ideas?
Paul
CrimpOn
Nov 25, 2021Guru - Experienced User
Random thoughts:
- Firmware V2.7.3.22 is a contentious subject on the forum. I experience no problems with it on either of my two Orbi RBR50 systems, but there have been many posts describing everything from continuous disconnections to outright failure. There are many users who sincerely believe that a previous firmware version is 'stable' and V2.7.3.22 is not and they want to return to that stable version. This is an complicated task because Netgear will almost immediately force an update back to V2.7.3.22. These users have resorted to some drastic measures to combat this. (Some have installed routers ahead of the Orbi to block update access. Another has signed up for OpenDNS to block updates. One has even recompiled the Orbi source code with a change that blocks the updates!)
If your Orbi was not functional, reverting firmware and blocking updates appears to be the only solution. - My sense is that the system is working in terms of actual user devices and the issue is that the Orbi does not correctly list devices that are connected to the network. And, this happens only when a satellite backhaul uses ethernet rather than WiFi.
- It appears to me that this is a question of "which is more important?" (a) getting maximum performance, or (b) having device information that is correct. Thousands of customers never look at their WiFi systems. Heck, from what I see on my neighborhood WiFi scans, plenty of customers do not even change the default WiFi credentials that came with their systems. For sure they are not puttering around with static IPs, etc. I have 200mb service from Spectrum and three satellites all backhauled over WiFi. I see absolutely no performance issues, but then I am not a 'power user'. We have not 'cut the cord' and thus still get television over cable rather than internet. My guess is that we could easily stream two 4K video streams and still not notice any problems. If we had four people playing World of Bunny Hop while streaming multiple TV's, etc. etc., maybe a wired backhaul would make a difference.
- Another example is when I connect directly to a satellite and display Connected Devices. (One of my pet peeves. Devices "Attach" to the router, but "Connect" to satellites. and no one in Netgear has ever told the engineers, "Hey. Pick one term and stick with it.")
Anyway, satellites seem to think the names of a lot of devices are "Unknown". Part of me says, "If this is worth putting on the satellite menu, it should be correct." My other side thinks that on a scale of 1 to 10, it ranks pretty low.
Geez. Ask a simple question and some old fart rambles on and on, but has no solution to offer. Sorry.
- PKleebergNov 27, 2021Tutor
CrimpOn
Fron one old fart to another, I find your replies educational though I agree the answer evades both of us.
I have finally switched both satellites to wired backhaul and I can still control devices that do not show up on the web or iPhone interface. I have had to reset a few of the WiFi devices to the network but they then operate fine once that is done.
I dread to think what I will need to do if I have to reboot the router. Thata is where I got into trouble last time. But for now, "If it ain't broke, don't fix it" prevails with the new configuration even though the web and iPhone app claims devices are not connected.
If I learn anything new, I will post it here.
Paul
- FURRYe38Nov 28, 2021Guru - Experienced User
How are the RBS connected to the RBR? Directly in back of the RBR or is there a LAN switch in between or using pre-existing in wall LAN cable system?
What CAT# cables are you using? CAT6 is recommended.
PKleeberg wrote:
CrimpOn
Paul
- PKleebergNov 30, 2021Tutor
I am using cat 5e. I laid all the LAN cable myself ~10 years ago.
Router -> 16 Port 1G switch -> 8 port 1G switch -> Satellite 1
Router -> 16 Port 1G switch -> 4 port 1G switch -> 8 port 1G switch -> Satellite 2
As I said earlier, everything appears to work deppite some devices missing from browser and app inrerface showing them as off line.
Paul
