KeithI
Apr 29, 2018Aspirant
Switching between 2.4g and 5g.
My wifi security cameras are reporting poor wifi connection (despite only being about 20 ft from the Orbi satellite. In the documentation for the cameras (Swann Smart Security Cameras) it says " If ...
Apr 29, 2018Guru - Experienced User
Orbi systems are based on Automatic assignment of devices based with what devices support, signal and range and using 1 SSID for both radios. Orbi doesn't officially support separating SSIDs since this is a MESH system which is all automatic using 1 SSID by design.
If you place one of these cameras in close range, doe it connect to the 5ghz portion of the system?
You might disable MIMO, Daisy Chain and Fast Roaming and test...
Set manual channel 48 on 5Ghz
KeithI
Apr 30, 2018Aspirant
Many thanks. Both cameras are reported as being on 5G in the Orbi router info. They were set up about 2 feet from the router and then placed, temporarily about where I need them. I think MIMO etc is disabled (no check mark against them in the router pages). Set manual channel 48? Where do I do that?
The cameras report the signal strngth as 6% & 1% and are located no more than about 6m or so from the satellite with one single brick wall between.
