jetguat
Jan 09, 2022Tutor
Synology DS918 access only via ipAddr instead of Hostname using ORBI
I have a Synology DS918 network shared on my home network. its connected via ethernet. I have an ORBI system that provides the wifi to the house. The two desktop PCs are conencted to the etherne...
- Jan 09, 2022
I think you run the ORBI in router mode. Either connect all devices (wired ones) to the ORBI's or set the ORBI to AP mode.
Ha_Ku_Na
Jan 09, 2022Luminary
- jetguatJan 09, 2022Tutor
Hi. I can try that. I've been trying to access the orbi via ethernet, and maybe thats not allowed.
when I use the ORBI app, I have gone through (I thought) all the menu options.
I am not seeing anywhere that indicates that the ORBI router or satellite are acting in AP mode or any other mode.
where do I verify or change those settings?Update: I found that I can only connect directly to the ORBI if the accessing pc is on the same network. Since the orbi provides wifi, not ethernet. accessing the orbi with the ethernet didnt seem to work. however I could use orbilogin.com via my mobile browser and see the setup and config. I see how within advanced router settings there is the Operation mode.
I cannot find the manuals that explain these operations modes. So what should I expect if I change to AP mode?- jetguatJan 09, 2022Tutor
The solution - thanks for the assistance - was to setup the ORBI into the Access Point (AP) operational mode. I could not figure how to tod that initial, as I was unable to access the orbi directly. Once I accessed the ORBI via a mobile browser connected on the same network via wifi, then I was able to get into the configuration and change the operational mode.
all is well. Thanks for the help and assistance- FURRYe38Jan 10, 2022Guru - Experienced User
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Enjoy. 📡
