capello
Jun 21, 2017Aspirant
synology NAS connected to Orbi Router via ethernet port not accesible
Hi, I just installed my Orbi system today. I have the system itself in AP mode, and the network is working fine. However my Synology NAS which is connected via ethernet to the Orbi Router cannot...
- Jun 22, 2017Yep different ip range is causing issues. Set your Nas to DHCP and try again. Your NAS may be in static IP mode as it should but in this case you need DHCP first then change it later.
OrbiMan
Jun 22, 2017Luminary
