OrbiPhilip
Mar 15, 2020Luminary
System logs
I would like to pull a history of the internet interface connection status. Is there a comprehensive system log available for Orbi? The one on the Advanced - > Administration -> Logs page is just ...
theoak
Every time the router reboots, the logs get cleared. So that is frustrating.
I have noticed at http://orbilogin.net/debug.htm you can set some log options. It almost seems to suggest that if you insert a USB memory stick it may save them off. You may need to try differnt formats (FAT32, EXT2/3/4, etc) until it is recognized by the Orbi. You may need to find some free disk utilities.
Something to try. Other folks can probably provide additional guidance.
CrimpOn
Mar 15, 2020Guru - Experienced User
I have used a USB stick to capture LAN/WAN traffic many times. However, only the LAN and WAN traffic captures appear on the USB stick. The "debug" information remains in memory.
- OrbiPhilipMar 16, 2020Luminary
It seems that Netgear only developed enough of each feature to list it on the box as being present. I cannot think of a single one where I thought "Wow, this is really well done".
- CrimpOnMar 18, 2020Guru - Experienced User
I took another look at the results of doing a Debug Capture. When the debug file is copied to my computer, there are LOTS of log files contained in "debug_log.zip". Although the "Orbi Log" that is available on the web interface is cleared when the Orbi reboots, many of these log files are not. I have no clue how to interpret many of these logs, but there certainly are a lot of them!
