OrbiPhilip
Mar 15, 2020Luminary
System logs
I would like to pull a history of the internet interface connection status. Is there a comprehensive system log available for Orbi? The one on the Advanced - > Administration -> Logs page is just ...
CrimpOn
Mar 15, 2020Guru - Experienced User
I have used a USB stick to capture LAN/WAN traffic many times. However, only the LAN and WAN traffic captures appear on the USB stick. The "debug" information remains in memory.
OrbiPhilip
Mar 16, 2020Luminary
It seems that Netgear only developed enough of each feature to list it on the box as being present. I cannot think of a single one where I thought "Wow, this is really well done".
- CrimpOnMar 18, 2020Guru - Experienced User
I took another look at the results of doing a Debug Capture. When the debug file is copied to my computer, there are LOTS of log files contained in "debug_log.zip". Although the "Orbi Log" that is available on the web interface is cleared when the Orbi reboots, many of these log files are not. I have no clue how to interpret many of these logs, but there certainly are a lot of them!
