flkayak
Feb 10, 2021Tutor
Tablo not working with Orbi now
Greetings All, I have an Orbi RBK router with 2 satellites that I have been using for quite a while, and have had no issues using a Tablo Dual unit hard wired from a satellite, which in turn is hard...
- Feb 10, 2021
flkayak wrote:TAblo support blames the "mesh" router system. If the unit is hard wired with ethernet cable and is not using wifi, what does it matter.
Your analysis is (obviously) correct, as no WiFi is involved in the connection. I would start with the Tablo User Manual where it describes how to set up the network connection. Then, look at the Orbi Attached Devices display. Does the Tablo device appear?
flkayak
Feb 11, 2021Tutor
Thank you suggesting I look at attached devices. I dont typically even use the app, but when checking devices, I did see what was identified as a google chromecast connected to the satellite, AND the internet access was not turned on. I turned on the access, and the tablo was able to scan channels and download the guide. Not sure how the access was turned off since I never mess with the configuration, but I renamed the device to Tablo and will take a look if this happens again.
CrimpOn
Feb 11, 2021Guru - Experienced User
My intention was to look at the Orbi web interface, not the Orbi "app". I have had mysterious things happen when using the "app", especially with regard to that "Pause" slider control. I do not activate Access Control. (If someone can figure out my 25 character WiFi password, they deserve free internet.) Access Control means that I have to be aware constantly when trying out a new gizmo, "Oh, I need to get on the Orbi and change access control."
Anyway, I have found that the "app" slider has activated access control on my Orbi when I did not intend for it to. I look at the Attached Devices page on the Orbi web interface and it says "Access Control ON." (swearing) go to Advanced Tab, Security, Access Control, uncheck box, click "Apply" (more swearing).
Glad you have TV again.
