PSUHammer
Mar 18, 2019Luminary
TCL Roku TV (r617) has bandwidth issues on Orbi 5GHz band
I am running a Plex server on my LAN and all of my devices are full Gig Ethernet except for my TCL Roku TV which is only 10/100. This presents a challenge when streaming uncompressed UHD Blu Ray cont...
- Mar 22, 2019
So, after much deliberation, I solved my issue. I had to buy an Nvidia Shield with a full gig Ethernet port to use for streaming to this TV.
michaelkenward
Mar 19, 2019Guru - Experienced User
If no one can suggest wifi tweaks, it might be a good idea to check out with the Roku experts – I don't see much traffic on that topic here.
When you say:
Buffering happens when the bit rate tops 100 mbps.
it is hard to see how you can do much about that if 100 Mbps is all the TV can handle, but one way to squeeze a bit more out of the network might be a wired connection to the TV. Wired always beats wifi. Does the TCL Roku TV support wired LAN?
If you can't run wires around the place, then you can now get Powerline Networking that Gb Ethernet. People often overlook Powerline, partly because the original implementations were less than great. Things have moved on since then,
PSUHammer
Mar 19, 2019Luminary
Hi Michael,
Thanks for the suggestions. Unfortunately, as I stated, the NIC on the TV only supports 10/100 and is not full gig. Major oversight by Roku/TCL in my opinion, especailly now with UHD content going over 100mbps occasionally.
This should not be a major issue as the Wireless radio does support 802.11ac. Using my Samsung Galaxy S8+, I am able to pass over 270mbps over the Orbi 5GHz band. In theory, and on paper, the TV should do the same. But I am only seeing speeds of about 40-50mbps on the 5GHz band through the TV itself.
I have a suspicion that it has to do with the TV/Roku wireless driver. It doesn't seem to really support 802.11ac speeds.
For the record, I have the Orbi base sitting right next to the TV.
- michaelkenwardMar 19, 2019Guru - Experienced User
PSUHammer wrote:
Hi Michael,
My point was that 100 Mbps wired (Powerline) LAN might be better than whatever you are getting with wifi.
Should be easy then to wire the TV to the network. No harm in trying, especially if it does track back to the TV's wifi drivers.
- PSUHammerMar 19, 2019LuminaryI probably should have been more clear. I always go wired first for my media streaming devices. UHD content buffers over Ethernet which led me to realizing the NiC in the TV was only 10/100. This is the reason I was attempting wifi as the theoretical throughput of 802.11ac is much higher than the 100mbps that the NIC is limited to.
- FURRYe38Mar 19, 2019Guru - Experienced User
What are the connection rates supported by the TV for its wireless adapter?
