PSUHammer
Mar 18, 2019Luminary
TCL Roku TV (r617) has bandwidth issues on Orbi 5GHz band
I am running a Plex server on my LAN and all of my devices are full Gig Ethernet except for my TCL Roku TV which is only 10/100. This presents a challenge when streaming uncompressed UHD Blu Ray cont...
- Mar 22, 2019
So, after much deliberation, I solved my issue. I had to buy an Nvidia Shield with a full gig Ethernet port to use for streaming to this TV.
PSUHammer
Mar 19, 2019Luminary
I probably should have been more clear. I always go wired first for my media streaming devices. UHD content buffers over Ethernet which led me to realizing the NiC in the TV was only 10/100. This is the reason I was attempting wifi as the theoretical throughput of 802.11ac is much higher than the 100mbps that the NIC is limited to.
Mar 19, 2019Guru - Experienced User
What are the connection rates supported by the TV for its wireless adapter?
- PSUHammerMar 19, 2019Luminary
The TV is advertised as supporting 802.11ac 2x2 Dual Band (support 2.4GHz & 5GHz). This is consistent with most newer Roku streaming devices.
Again, I have to think the issue is in the firmware on the TV. The strange thing is the TV prefers the 2.4GHz signal over the 5GHz signal.
- FURRYe38Mar 20, 2019Guru - Experienced User
Check to see if there is any FW updates for the TV.
Connection rates I was referencing were if the Mfr of the TV mentioned anywhere about what rate speeds the TV supports, not modes. Smoething like 300-600mb on 2.4Ghz or 867-1300Mb on 5Ghz? These are connetion rates.
- PSUHammerMar 20, 2019LuminaryGotcha. As it is a Roku TV, it uses Roku firmware and is always up to date with what is available. Unfortunately, Roku and TCL do not advertise those details. I can ask. Their wireless settings are very dumbed down and basic.
