PSUHammer
Mar 18, 2019Luminary
TCL Roku TV (r617) has bandwidth issues on Orbi 5GHz band
I am running a Plex server on my LAN and all of my devices are full Gig Ethernet except for my TCL Roku TV which is only 10/100. This presents a challenge when streaming uncompressed UHD Blu Ray cont...
- Mar 22, 2019
So, after much deliberation, I solved my issue. I had to buy an Nvidia Shield with a full gig Ethernet port to use for streaming to this TV.
PSUHammer
Mar 19, 2019Luminary
The TV is advertised as supporting 802.11ac 2x2 Dual Band (support 2.4GHz & 5GHz). This is consistent with most newer Roku streaming devices.
Again, I have to think the issue is in the firmware on the TV. The strange thing is the TV prefers the 2.4GHz signal over the 5GHz signal.
Mar 20, 2019Guru - Experienced User
Check to see if there is any FW updates for the TV.
Connection rates I was referencing were if the Mfr of the TV mentioned anywhere about what rate speeds the TV supports, not modes. Smoething like 300-600mb on 2.4Ghz or 867-1300Mb on 5Ghz? These are connetion rates.
- PSUHammerMar 20, 2019LuminaryGotcha. As it is a Roku TV, it uses Roku firmware and is always up to date with what is available. Unfortunately, Roku and TCL do not advertise those details. I can ask. Their wireless settings are very dumbed down and basic.
- FURRYe38Mar 20, 2019Guru - Experienced User
Ok, ya sometimes you can get those details which for some of us, is important. It's nice to know what devices at actually connecting at with the wireless radios. If your trying to stream 1080p or 4k and the TV is only connecting at say 867mb on 5Ghz AC, then is may or may not be good enough to handle the bandwidth needed by the streaming data. 1300Mb would be best. However for simple low video or music, 300Mb to 867 works ok. This would be helpful to know what the TV is actually connecting at. Something Roku should know about.
- PSUHammerMar 22, 2019Luminary
- PSUHammerMar 23, 2019Luminary
Forgot to add...I spoke to TCL and have been working with Roku. Neither publish or give out more Wireless specs than what is available in their menus on the TV. It's too bad as they give very little data.
- PSUHammerMar 26, 2019Luminary
I have no idea of this is the Orbi's fault or if it is TCL/Roku. The TV just updated to Roku version 9.0 which adds more details to the Network status page in their menu. They now show the tested bandwidth throughput for each network connection. Here is what I found:
So, my TCL TV just updated to v9.0. This has added the bitrate line to the network status page. I tested all three of my network options. Here is what the Roku finds:
1) Ethernet = 95 Mbps (no surprise)
2) Wifi 5GHz band = 46 Mbps (crappy with 802.11ac)
2) Wifi 2.4 GHz band = 76 Mbps (fine for N)
Mind you, the Orbi base router is literally 8 inches from the TV and my phone pulls 270 Mbps on the 5GHz band.
