PSUHammer
Mar 18, 2019Luminary
TCL Roku TV (r617) has bandwidth issues on Orbi 5GHz band
I am running a Plex server on my LAN and all of my devices are full Gig Ethernet except for my TCL Roku TV which is only 10/100. This presents a challenge when streaming uncompressed UHD Blu Ray cont...
- Mar 22, 2019
So, after much deliberation, I solved my issue. I had to buy an Nvidia Shield with a full gig Ethernet port to use for streaming to this TV.
Mar 20, 2019Guru - Experienced User
Ok, ya sometimes you can get those details which for some of us, is important. It's nice to know what devices at actually connecting at with the wireless radios. If your trying to stream 1080p or 4k and the TV is only connecting at say 867mb on 5Ghz AC, then is may or may not be good enough to handle the bandwidth needed by the streaming data. 1300Mb would be best. However for simple low video or music, 300Mb to 867 works ok. This would be helpful to know what the TV is actually connecting at. Something Roku should know about.
PSUHammer
Mar 22, 2019Luminary
