PSUHammer
Mar 18, 2019Luminary
TCL Roku TV (r617) has bandwidth issues on Orbi 5GHz band
I am running a Plex server on my LAN and all of my devices are full Gig Ethernet except for my TCL Roku TV which is only 10/100. This presents a challenge when streaming uncompressed UHD Blu Ray cont...
- Mar 22, 2019
So, after much deliberation, I solved my issue. I had to buy an Nvidia Shield with a full gig Ethernet port to use for streaming to this TV.
Mar 20, 2019Guru - Experienced User
Ok, ya sometimes you can get those details which for some of us, is important. It's nice to know what devices at actually connecting at with the wireless radios. If your trying to stream 1080p or 4k and the TV is only connecting at say 867mb on 5Ghz AC, then is may or may not be good enough to handle the bandwidth needed by the streaming data. 1300Mb would be best. However for simple low video or music, 300Mb to 867 works ok. This would be helpful to know what the TV is actually connecting at. Something Roku should know about.
PSUHammer
Mar 23, 2019Luminary
Forgot to add...I spoke to TCL and have been working with Roku. Neither publish or give out more Wireless specs than what is available in their menus on the TV. It's too bad as they give very little data.
- PSUHammerMar 26, 2019Luminary
I have no idea of this is the Orbi's fault or if it is TCL/Roku. The TV just updated to Roku version 9.0 which adds more details to the Network status page in their menu. They now show the tested bandwidth throughput for each network connection. Here is what I found:
So, my TCL TV just updated to v9.0. This has added the bitrate line to the network status page. I tested all three of my network options. Here is what the Roku finds:
1) Ethernet = 95 Mbps (no surprise)
2) Wifi 5GHz band = 46 Mbps (crappy with 802.11ac)
2) Wifi 2.4 GHz band = 76 Mbps (fine for N)
Mind you, the Orbi base router is literally 8 inches from the TV and my phone pulls 270 Mbps on the 5GHz band.
