meilge
Apr 02, 2019Aspirant
Tech Support
Can anyone tell me how to actually contact tech support. Their website clearly states that I am entitled to complimentary telephone support for 90 days but no where does it provide a phone number. Th...
Apr 02, 2019Guru - Experienced User
What NG product do you have?
Have you filed a ticket here?
meilge
I have an Orbi. I have not filed a ticket. I'm trying to take advantage of the free telephone support that I am entitled to.
- FURRYe38Apr 02, 2019Guru - Experienced User
I believe you have to file a ticket first and give the details of the problems. Then someone at NG will review and then you'll be able to contact NG via phone.
If there is a problem, maybe we can help here as well.
- michaelkenwardApr 03, 2019Guru - Experienced User
meilge wrote:
I'm trying to take advantage of the free telephone support ...
It think it means "free support", not "free telephone support".
Netgear uses a chat system. Start it and, with luck, they call you.
But it may depend on where you are. In some countries you can end up with a phone number if you try starting a support session on line.
- meilgeApr 03, 2019Aspirant
Sir
Thank you for your response. When I registered the product it clearly stated complimentary "Telephone" support. Having said that, I couldn't find anywhere to start a chat session either. I don't claim to be an expert at using the internet but after spending a fair amount of time, the only way I could get help from Netgear was to go to the forum. Netgear is totally useless as far as I'm concerned.
They call you.
